Ilogic- dxf
Ilogic- dxf
Hello, I created ilogic to create dxf from the assembly. Unfortunately, the rack only works for parts, while when the assembly is in the next assembly it does not create dxf. Please help. Below the script
Sub Main Blacha()
Dim oDoc As AssemblyDocument '
oDoc = ThisApplication.ActiveDocument
Folder = ThisDoc.Path & "\DXF\"
Sciezka = InputBox("Folder docelowy", "DXF", Folder)
If Not System.IO.Directory.Exists(Sciezka) Then
System.IO.Directory.CreateDirectory(Sciezka)
End If
' Set a reference to the BOM
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
' Make sure that the PartOnly view is enabled.
oBOM.PartsOnlyViewEnabled = True
Dim oDef As AssemblyComponentDefinition
oDef = oDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
For Each oOcc In oDef.Occurrences
If oOcc.SubOccurrences.Count = 0 Then
If oOcc.DefinitionReference.ReferencedDefinition.Type = 150995200 Then
Dim oCompDefSM As SheetMetalComponentDefinition
oCompDefSM = oOcc.Definition
Dim oDataIO As DataIO '
oDataIO = oCompDefSM.DataIO
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2000&RebaseGeometry=True&SimplifySpline=True&InteriorProfilesLayer=IV_INTERIOR_PROFILES&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_ARC_CENTERS;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_UNCONSUMED_SKETCHES;IV_ROLL_ANGENT;IV_ROLL&SplineToleranceDouble=0.01"
Dim sFname As String
sFname = oCompDefSM.Document.FullFilename
el = oCompDefSM.FlatPattern.Length * 10
ew = oCompDefSM.FlatPattern.Width * 10
Pozycja=InStrRev(sFname,"\", -1)
NazwaPliku=Right(sFname,Len(sFname)-Pozycja)
NazwaPliku = Left$(NazwaPliku, Len(NazwaPliku) -4)
Gr = oCompDefSM.Thickness.Value * 10
Dim MTOBJ As Material
MTOBJ = oCompDefSM.Material
Dim MT As String
MT=MTOBJ.Name
PN = iProperties.Value(oOcc.Name, "Project", "Part Number")
quantity = ThisBOM.CalculateQuantity("Parts Only", PN)
tytul = iProperties.Value(oOcc.Name, "Summary", "Title")
''''''''''''''''' TU ZMIEŃ ''''''''''''''''''''''''''''
sFname = Sciezka & PN & " " & tytul & " " & Round(el) & "x" & Round(ew) & "x"& Gr & " " & MT & " sztuk " & quantity & ".dxf"
If oCompDefSM.HasFlatPattern = False Then
oCompDefSM.Unfold
oDataIO.WriteDataToFile(sOut, sFname)
oCompDefSM.Document.Close(True)
Else If oCompDefSM.HasFlatPattern = True Then
End If
End If
Else
Call SprawdzPodzespol(oOcc, Sciezka)
End If
Next
InventorVb.DocumentUpdate()
End Sub
Private Sub SprawdzPodzespol(ByVal oCompOcc As ComponentOccurrence, Sciezka1 As String)
Dim oSubOcc As ComponentOccurrence
For Each oSubOcc In oCompOcc.SubOccurrences
If oSubOcc.SubOccurrences.Count = 0 Then
If oSubOcc.DefinitionReference.ReferencedDefinition.Type = 150995200 Then
oCompDefSM = oSubOcc.Definition
Dim sOut As String
Dim MT As String
MT=MTOBJ.Name
PN = iProperties.Value(oSubOcc.Name, "Project", "Part Number")
sFname = Sciezka1 & NazwaPliku & " " & Round(el) & "x" & Round(ew) & "x"& Gr & " " & MT & " sztuk " & quantity & ".dxf"
oCompDefSM.Unfold
End If
End If
Else
Call SprawdzPodzespol(oOcc, Sciezka1)
End If
Next
End Sub
