iLogic Copy Rules
iLogic Copy Rules
Provide the ability to RMB on a rule in the iLogic browser and copy that rule within the part or assembly or to another part or assembly. The ability to rename the rule and begin to quickly edit the rule to make the necessary changes.
11 Comments
dusan.naus.trz
It probably is not what you wanted?
http://beinginventive.typepad.com/being-inventive/2012/02/injecting-ilogic-code-and-ilogic-event-tri...
I would like to code injector was in Inventor, because of higher versions of Inventor compatibility.
if you use a generator shaft or tube and pipe generator will not work, but otherwise everything works.
thumbs up
Cheers
Dusan
I agree with user nausd
SharkDesign
I would like to be able to copy a rule from the iLogic browser and paste it into the iLogic browser of another part.
You can do this with forms so I don't know why you can't with iLogic.
Tags (3)
SharkDesign
Sorry, this is a duplicate, for some reason it didn't come up the first time I searched.
Please delete as I don't think I have the access to do so.
Kay_Rethmeier
Hi Autodesk,
provide the posibility to copy and paste rules by clicking on the rule with RMB - Copy and the posibility to paste into a different document-iLogic-browser.
Bye
Kay Rethmeier
Senior System Consultant
Tags (1)
karthur1
Yes... ability to do this would be much easier that the long handed way of doing it now.  Similar to this idea.
karthur1
I found a similar post that is dated 12/13/2017 here by Kay.Rethmeier .  Both similar ideas.... I voted for both.
Need the ability to copy iLogic rules.
dan_szymanski
Idea added to backlog for future consideration [3641]. Thanks!
dan_szymanski
Status changed to: Accepted
Accepted idea [3641]. Thanks!
Yijiang.Cai
It has been available in Inventor 2022.1, and you could have a try.
Kay_Rethmeier
Cool, congratulations! Perfect fast development!!
