iLogic : Copy and paste rules
Actually you have to open the rule you want to copy, copy the code, create a new rule in the new part or assembly, open it and paste the code.
It would be helpful if it is possible to copy and paste the rule.
6 Comments
johan.degreef
and to copy "this rules" to these documents.
Curtis_Waguespack
Hi @A.Hoeveler
here is a sample rule that copies internal rules from one file to another
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
'create list
Dim oList As New ArrayList
' Define the iLogic addin
Dim iLogicAddIn As ApplicationAddIn = _
   ThisApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
' Get the iLogic automation object
Dim iLogic As Object = iLogicAddIn.Automation
'get collection of rules
Dim ruleName As String
Dim rules As Object
rules = iLogicVb.Automation.Rules(oDoc)
'make sure there are rules in the file
'and then add them to the list
If Not (rules Is Nothing) Then
	For Each rule In rules
		ruleName = rule.Name
		oList.Add(ruleName)
	Next
Else
	'no rules found
	Return 'exit rule
End If
'get user input
sRuleName = InputListBox("Select a Rule to copy", _
oList, oList(0), "iLogic", "List")
If sRuleName = "" Then
	Return
End If
'get rule text
For Each iRule As iLogicRule In rules
	If iRule.Name = sRuleName
		oRuleText = iRule.Text
	End If
Next
'get list of open documents
oList.Clear
For Each oDoc In ThisApplication.Documents.VisibleDocuments
	oList.Add(oDoc.DisplayName)
Next
'get user input
oDocName = InputListBox("Select an destination file", _
If oDocName = "" Then
	Return
End If
'get the rules in the destination doc
	If oDocName = oDoc.DisplayName Then
		Exit For
	End If
Next
'and make sure a rule of the same name is not present
		If sRuleName = rule.Name Then
			MsgBox("A rule named " & sRuleName & _
			   " already exists in " & oDoc.DisplayName, , "ilogic")
			Return 'exit rule
		End If
	Next
End If
'copy the rule to the document
Try
	iLogic.AddRule(oDoc, sRuleName, oRuleText)
Catch
	MsgBox("something went wrong", , "iLogic")
End Try
Yijiang.Cai
It has been available in Inventor 2022.1, and you could have a try.
marcin_bargiel
Implemented is only copy ONE rule; why can't we copy & paste many rule at once ?!
It's hard to even comment on that, honestly.
e_Ibrisimovic
Observer
here you go
Dim oDoc As Document = ThisApplication.ActiveDocument
' iLogic automation object
Dim iLogicAddIn As ApplicationAddIn = ThisApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
' Ophalen van regels
Dim allRules As Object = iLogic.Rules(oDoc)
If allRules Is Nothing Then
    MsgBox("Geen regels gevonden.", , "iLogic")
    Return
End If
Dim selectedRules As New List(Of String)
Do
    oList.Clear()
    For Each rule In allRules
        If Not selectedRules.Contains(rule.Name) Then
            oList.Add(rule.Name)
        End If
    Next
    oList.Add("Klaar") ' Voeg "Klaar" toe als stopoptie
    Dim pick As String = InputListBox("Selecteer een regel (of 'Klaar')", oList, oList(0), "iLogic", "Regel Selectie")
    If pick = "Klaar" Or pick = "" Then Exit Do
    If Not selectedRules.Contains(pick) Then selectedRules.Add(pick)
Loop
If selectedRules.Count = 0 Then
    MsgBox("Geen regels geselecteerd.", , "iLogic")
    Return
End If
' Selecteer bestemmingsbestand
oList.Clear()
Next
Dim oDocName As String = InputListBox("Selecteer doelbestand", oList, oList(0), "iLogic", "Bestand")
If oDocName = "" Then Return
' Zoek doelbestand
Dim targetDoc As Document = Nothing
For Each doc In ThisApplication.Documents.VisibleDocuments
    If doc.DisplayName = oDocName Then
        targetDoc = doc
        Exit For
    End If
Next
If targetDoc Is Nothing Then
    MsgBox("Doelbestand niet gevonden.", , "iLogic")
    Return
End If
' Haal regels van doelbestand op
Dim targetRules As Object = iLogic.Rules(targetDoc)
' Voeg regels toe
Dim conflictRules As New List(Of String)
For Each ruleName In selectedRules
    ' Zoek de tekst van de regel
    Dim ruleText As String = ""
        If rule.Name = ruleName Then
            ruleText = rule.Text
            Exit For
        End If
    Next
    ' Controleer of regel al bestaat
    Dim exists As Boolean = False
    For Each tr In targetRules
        If tr.Name = ruleName Then
            conflictRules.Add(ruleName)
            exists = True
            Exit For
        End If
    Next
    If Not exists Then
        Try
            iLogic.AddRule(targetDoc, ruleName, ruleText)
        Catch ex As Exception
            MsgBox("Fout bij kopiëren van regel '" & ruleName & "'", , "iLogic")
        End Try
    End If
Next
' Toon eventueel conflicten
If conflictRules.Count > 0 Then
    MsgBox("De volgende regels zijn niet gekopieerd omdat ze al bestaan:" & vbCrLf & String.Join(vbCrLf, conflictRules), , "iLogic")
Else
    MsgBox("Regels succesvol gekopieerd!", , "iLogic")
End If
marcin_bargiel
Thanks a lot for the code and inspiration! Based on it, I created a rule for copying/deleting selected or all rules and forms, but with a slightly faster selection from a single list...
Many thanks!
I don't even want to comment on the fact that this isn't standard 😕
