Show only
Search instead for
@david.wager, the following object path will get you the dimensions associated with the Title Block on a given sheet, which you can then modify as you wish:
I recommend using the API reference manual for further help, or asking for help on the regular forms if necessary. What you want to do via iLogic/API is already possible.
