Icon Customization for external iLogic rule ribbon Button
In Inventor 2023 we finally got ability to setup ribbon buttons for our external iLogic rules (Thanks a lot!)
Yet, such buttons is hard to distinguish with "Text Off" mode active (because of standard "iLogic script" icon is used for all such buttons). This seems a step back comparing to icon customization logics that is already released for external rules within iLogic panel*.
I'd rather say we need support of the same icon-customization logics for the above-mentioned buttons.
Quotation from "To Work with Rules in iLogic" Help-subclause:
"To create an icon for an external rule that appears in the iLogic browser, create a BMP or PNG file (size 16 x 16 is recommended) with the same name as the rule file, in the same folder. Restart Autodesk Inventor to display the icon."
7 Comments
Maxim-CADman77
BTW, It seems that Inventor badly needs some improvement regarding processing of transparency-containing icons of custom Add-In button within Dark Theme.
I've discovered that PNG used as icon for Add-In Button looks blurry while it looks just nice when used as icon for iLogic Rule:
PS: Using solid dark-gray (ribbon) icon background don't seem to be a solution as it doesn't support MouseHover-interactivity (background of standard buttons changes to Black).
PPS: I've also tried "Button Constructor" (subject-related Add-In by
@JelteDeJong) but got the same "blurry" result.
UPDATE: I do get better result with using ICO instead of PNG:
Curtis_Waguespack
To create a custom icon for your iLogic Ribbon button:
  • Create a *.png file that is 16x16 pixels or 32x32 pixels
  • Place this image file in the same folder as the Rule resides in
  • Format the name to be as such:
    • <Name of the iLogic Rule or Form> . <light or dark> . <small or large> .png
Example:
iLogic rule name:  Create PDF
iLogic rule button image name: Create PDF.light.small.png
Restart Inventor if needed.
see related link:
https://forums.autodesk.com/t5/inventor-forum/inventor-2023-ilogic-rules-and-forms-on-ribbon/m-p/110...
Maxim-CADman77
Wow!
This works but with one small remark: Inventor seems to turn White (255,255,255) and Almost-White (ex. 254,254,254) backgrounds to transparent (which may give undesired result within Dark theme). I used to workaround this by using another color (253,253,253) for White background.
@Curtis_Waguespack  thank you and @mathijs.stevens !
PS:
How am I supposed to archive "my idea"?
Curtis_Waguespack
@Maxim-CADman77
I don't think we can do so, but someone from Autodesk looks at the ideas from time to time and will archive them as needed at that time, I wouldn't worry about it in the mean time.
Maxim-CADman77
@James_Willo
Could you, please, initiate/force adding corresponding info to Inventor 2023 online help?
Thank you in advance.
Could you please disable the function mentioned by @Maxim-CADman77 that makes white pixels transparent? It took me 3 darkening passes to make my icon look OK (without holes) and it's really annoying. If someone wants to have transparent background let them use the alpha channel of PNG and if some wants to use white background just let them have it.
f_calebh
@Maxim-CADman77
How did you get the .ico files to work for the dark theme issue? I'm using 2024 and can only get the png files to work.
