i-part & i-assembly generate members
When working with i-parts and/or i-assemblies, you have to generate each factory member to make the i-factory functional.  For each member instance, a "SAVE" pop-up box appears, asking if you want to save changes to the part and its dependents.  Effectively, it requires the user to keep hitting "OK" to save each member instance, rather than just saving the parts out automatically.
Can you please either eliminate this pop-up box and just save everything with a "yes" save status automatically, or at the very least add some kind of check box options to set the save behavior once, rather than manually clicking the same "OK" button over and over?
Currently using Inventor 2012.
1 Comment
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. The product team continually reviews this forum aiming to deliver in the most impactful way we can based on voting. We also regularly examine the list to make sure it reflects the most current Ideas. As part of this process we archive old Ideas that haven’t received broad support. This ensures there is room for new Ideas to be reviewed by the community and for the most relevant and meaningful ones to gain votes.
This Idea is archived because it's been on the board for over a year and hasn't received many votes. If you want to raise it again and try to gain more support across the community, you're welcome to do so. Leveraging images, animated gifs or sample mock-ups can help convey concepts and generate more votes from other users. If you have questions or see a connection between this Idea and others that should be accounted for, please let us know.
- INV.IdeaReview
