When in a sketch with several closed loops with some overlapping and some inside each other with shared lines its a hassle to select the ones you want to extrude (and use similar command on like rotate and so on).
Se screencast how it works now and how can this be good (the 4 small loops are to be selected).
Se picture how this should be done. Super fast and no hassle... No Select Other and what not... And you don't even se very good what loop is what. Please also redo the coloring (and maybe a texture) of selected loop, loop to be selected and so on so that its really easy to se what your doing. I think this also is very good when deselecting a loop from a sketch that is already extruded.
