Hole depth dimensions should reference the part surface.
Issue/Problem:
We created a 1/8" deep flat bottom spotface from the edge of a plate and then moved the edge of the plate 1/16" to shorten it's overall length without changing the depth of the spotface making the spotface now 1/16" deep. The hole note does not update accordingly and still shows the spotface depth at 1/8" as it was created from it's original reference surface. Short of dimensioning the diameter and depths seperately, the only solution I have foundis to remove the spotface and recreate it after the move face operation had been performed.  This applies to all hole types when referencing the depth of the hole feature.
Suggested solution:
Depth dimensions of holes (and other features) should always reference the surface it is shown being dimensioned from in the 2D drawing instead of the feature or workplane it was originally created from (that may not even exist any more).  This would allow feature changes and modifications to automatically update the depth callouts on the drawing.
The attached .ipt and .idw have a simple block showing some of the ways that holes can be created showing the dimensioning errors.  Here's a shot of what the .idw contains.  This was submitted to Autodesk support and it was suggested that I post it here as well.  Case ID: 10447780.
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
