Highlight features in the browser when selected from anywhere
Features and sketches should show up highlighted everywhere in the browser when they are selected.
20 Comments
When you click on a face in a part,  I would like the feature to automatically highlight in the model tree.  Currently, if you don't know how the part was created you have to cycle thru the features until you see it highlight on the model.  A "find in model tree" could also be used.
jtylerbc
This may not be EXACTLY what you want it to do, but I think it's pretty close, and may be better than how you're dealing with this now.
Much of what you want actually does happen if you use the Feature selection filter instead of the default "Faces and Edges" filter.  Switch this using the dropdown in the Quick Access Toolbar (top of the Inventor window) or by shift + right-click.  Once you are in this mode, selecting features will highlight the corresponding feature in the browser, and there will be a Find in Browser available on the right-click menu.
Forgot about selection filters, thanks jtylerbc.  Old habits die hard,, now if I could only find a way to delete this idea. Smiley Embarassed
P-D91
When you click on a face within a part; a command pops up where you can 'edit feature' (even when selection filter is set to faces and edges)
So it clearly knows what feature is associated with that face....
Why doesn't it highlight it in the feature tree on the left hand side.
Can this be a thing?
Cheers
DRoam
This is a good suggestion. I think Inventor should have a "upper-level" highlight style that looks slightly different from the normal highlight, and tells you "the thing you have selected is CONTAINED by this". This would be extremely handy for tracking down where something is in the Browser.
For example, selecting a Part which is inside of a sub-assembly which is inside of a Pattern would highlight the Pattern using the "upper-level" highlight style (maybe it could be a blue box rather than a full highlight, similar to the red box when pre-selected). And expanding the Pattern would reveal the containing Assembly highlighted using the upper-level highlight style. Finally, expanding that would reveal the Part selected.
Same for faces/features in Parts. Selecting a face would highlight the containing feature using the upper-level highlight style, so that you can easily find which feature contains it but without the misconception that you selected the feature rather than the face.
This upper-level highlight style would also be applicable to this idea: Make it easier to determine what constraints are constraining.
DRoam
Good idea. Here's a related one: Find a solid body feature in the Browser history/feature tree.
(tagging voters of this idea in case you want to vote on the linked idea: @jtylerbc, @-niels-, @Anonymous, @Anonymous, @jeremy_wasserstrass, @Anonymous). Thanks!
andrewdroth
Yes! I was thinking that Find in browser would be appropriate too!
Anything to help jump around the browser.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
nthomasH8FXK
As a long-time user of another widely used 3D CAD software I am used to, when working in assembly, selecting a part and seeing it highlighted in the model tree/browser.  If the tree is long enough that it needs scrolling to see all of it, the part is highlight and the tree automatically moves to make the part visible.
When working with a part, I can click on any face, edge, body, etc and it should highlight the corresponding feature and move the tree as outlined above.
I am so frustrated by needing to use a selection filter.  Why do we need to select a filter to specify a face, body, surface, edge, etc., and maybe get what I am looking for highlighted in a visible spot on the browser tree. I would like to see it work so that I click on the part, face, edge etc. and see it in the Browser Tree, without having to RC and do an additional command.
mhall55ULE
Agree with nthomasH8FXK wholeheartedly!!!
Definitely - this function exists for wireframes but inexplicably not for solids....?!
P-D91
Still no movement on this, and it still bugs me to this day...
HELLO! Anybody out there?!?!?
janlH747C
Observer
I would also like that feature, I have just started using Inventor again after several years in Solidworks and Creo, where this is a common feature. What does you guys from Autodesk think of it ?
peter.kapitola
Agreed. This is very notable in its absence (coming to Inventor from SolidWorks)
The functionality exists to some extent - just hover the mouse over the "edit" contextual button and it will highlight the feature in the browser.
Yijiang.Cai
When set the feature as top selection priority, the browser node will be highlighted when selecting feature in graphic window. But only the first level of feature node will be highlighted, and the feature node under solid or somewhere will not be highlighted. Do you want to highlight all the feature nodes related to the selected feature?
River
andrewdroth
@Yijiang.Cai "Do you want to highlight all the feature nodes related to the selected feature?"
Yes.
Yijiang.Cai
@andrewdroth , many thanks for the quick response!
It has been tracked as [INVGEN-56238].
matteo_bianchiniN827C
if you click on the feature and hover over edit feature, it will highlight in tree
purchasingWB7LX
Changing selectrion filter "Feature Priority -> Select Features" seems to enable such behaviour.
