have the iLogic window and the parameter window open simulatiously
When coding iLogic you often need to check, add, rename or checkmark "key" or "export" in the parameter window.
In order to do this you need to close your iLogic window you are working in, open the parameter window, do whatever you need to do in the parameterwindow, close it, and open your iLogic window again.
Since many engineers have two monitors or are using an ultrawide, you can easilly have both windows open at the same time (if that would be possible).
It would be much more efficient if both windows would be open and usable at the same time.
1 Comment
dan_szymanski
This idea has been implemented within Autodesk Inventor 2027. Please review the Inventor 2027 What's New article here, for more information regarding how the parameters dialog box is now modeless (ie "permanently open" and able to store on another monitor). Special thanks to Lune & everyone who cast a vote for it!
