Have Dropdown to switch between rules - iLogic Editor
It would really cool to be able to quickly switch between rules in a document. This would be helpful if you want to copy a line of code you have in a different rule. But to do this now you have to close the rule, open the other rule, copy, open the rule you had open and then paste. If you had a dropdown that would allow you to quickly switch between rules would speed up that functionality.
2 Comments
JBerns
WCrihfield
If they do add a control in there for switching between multiple iLogic rules, then it would be awesome if they also built-in some behind the scenes support functionality for that system that would remember the 'location' (line number or previous scroll position) of the rule you just switched away from, so it would go back to that same exact location again when we switch back to that rule again.  That would make that transition super smooth & fast.  But it doesn't have to stop there.  Accessing just the rules in the 'current' document would be OK, but if I could 'pick out' (using file browser or an intuitive, filtered list) 2 or more other external rules, that would be even better.
