Half/Quarter section view
It would be handy to be able to unselect parts from a half or quarter section view, or the other way around; pick certain parts to be viewed in half/quart. This would make placement of constrains much more easy.
5 Comments
You can already achieve this (although there are drawbacks to the current process.
For the Part(s) or Subassemblies in question under the document settings you can turn off Section Participation, however this will affect All sections in both assemblies and drawings
Hope this helps
silo15
Can't make this happen in the 3D model, only in drawings, or am I wrong? Tried the one above, but couldn't make it work.
It should work as I tested it at the time I made the post just to make sure, you may have to redo the section or update the model before it changes perhaps?
I'm trying to do this too; The option simply isn't present under the modelling tab of the document settings. Anyone have an idea?
Apologies for the double post: I just realized the option is only present for individual parts, not for assemblies... ouch!
