General improvement of processing higher number of occurrences in assemblies via iLogic
Hello.
General improvement of processing higher number of occurrences in assemblies via iLogic is needed.
This is used in various environments, changing the browser node names, processing edges in drawings, ...
We had 2 example assemblies:
  • Smaller assembly with cca 1200 occurrences.
  • Bigger assembly with cca 14000 occurrences.
To process cca 1200 occurrences, code needed:
  • Smaller assembly --> cca 5 seconds
  • Bigger assembly --> cca 38 seconds
So to process the same number of occurrences, code needed almost 8 times more time, which has a huge impact on the workflow and engineering time. It does even worse, if assemblies have even more occurrences.
Example code for testing:
Dim oDoc As Document = ThisDoc.Document
Dim statusCount As Integer = 0
Dim totalCount As Integer = oDoc.ComponentDefinition.Occurrences.Count
For Each occ In oDoc.ComponentDefinition.Occurrences
	statusCount += 1
	ThisApplication.StatusBarText = String.Format("Counter: {0} od {1}", statusCount, totalCount)
	Try
		oDoc.BrowserPanes.Item("Model").GetBrowserNodeFromObject(occ).NativeObject.Name = "Counter &" + statusCount
	Catch
		'Skip
	End Try
Next
Best regards,
Rene Repina
