function trim/extend
I would like to know if it would be possible to add a Split-Body capability to the Trim and Extend function for frame structures.
The idea would be that, instead of modifying both intersecting bodies, the selected frame member would be split into multiple bodies at the intersection, while the other member would remain unchanged and act only as the trimming reference.
This would save a lot of time when working with frames. I would no longer need to create additional sketch lines in the skeleton model or perform multiple trim operations. Being able to split a frame member directly within the Trim/Extend command would make the workflow much more efficient.
