I have a problem with adding a key column to the family table of a content center library and frame generator. The key column is the inspection document according EN 10204.
It is added to the size in the frame generator. I would like to have a separate drop down for each key column property in the library similar to the place from content center dialog.
For out of the box cc libraries it works fine. However when I want to add something which the user need to be able to select it doesn't work well. For example adding inspection document for the structural shape (EN 10204, there are several options, no inspection, 2.1, 2.2, 3.1, 3.2). I add a column to the family table and make it a key column so it is selectable. Now when I place from content center I can select the inspection document separately. Frame generator dialogue works different. It adds the key column to the size selection dropdown menu. Making in this case the list 5x as long/slower/harder to navigate. A separate dropdown for each key column would make selection a lot easier/faster similar to how the place from content center works.
Btw the same goes for added materials. It's makes the size selection drop down box way longer.
You can see the difference in the screenshots attached:
