When you are designing a frame, the frame generator tool is a really great tool to use. However when it comes to creating drawings it starts to become a nightmare, for example i have designed a frame with mulitple different members and plates etc i would like to be able to draw each column separate with its plates that are welded to it to do this i have to create a drawing view and turn off all the other frame parts to just see the the column i want with the required plates. In fusion 360 i believe there is a function that allows to select that you want to start a drawing and it lets you selects the parts that you want included this works great and would be nice in inventor
