Flat Pattern tools for adding 'green' material
I would like a tool for adding 'green' material (material that will be cut off later) to a flat pattern. This would work similar to the Thicken command in that you would select the edges/faces you want 'green' added to and how much material to add. However (very important) the original edge should be preserved in some way, preferably as a split line in the face so that this can be marked on during the cutting process.
The only current options for doing this are Move Face or by creating a sketch, drawing the 'green' and extruding it. In neither case is the original edge preserved.
The Split tool should also be added to the Flat Pattern work bench for adding additional mark lines. I know these can be done with sketches but splits are neater in some cases
4 Comments
PaulMunford
Are there any tools in the weldment envoironment that would help you with this?
pierre.masson
We need to model sheet metal using loft feature.Sometimes it's a lofted surface that we thicken.
Inventor Sheet Metal is not able to unfold them afterwards.
Tags (4)
r_lehmann79
Nice Idea, but I think this won't work. In my understanding, the Inventor Sheet Metal is only for parts with simple bendings. If you create parts with lofted surfaces, then you design parts that have to be manufactured by deep drawing. To unfold such complex parts you normally need special fem-based software. I don't know any standard-CAD-Software that can do this. Best regards Ralf
rob_bolter
If a thickened part does not unfold its because you have the wrong material thickness in the thicken feature. Use "Thickness" in that box and it should unfold, this is usually a problem if the thickness is entered manually and the sheet metal style is changed afterwards (no longer match).
As for the lofts, wouldnt they technically be another stage in the fabrication process, not at the sheet metal fabrication stage?
