Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fixed Length Extension lines for dimension lines
We'd need the ability to set a fixed length Extension line for Dimension line in the styles.
This is possible in Autocad.
4 Comments
rodney.pudneyTNG8B
I Fully agree with you.   This is very useful for dimensioning complex flat patterns and plates amongst other things....   i really miss some of Autocad's control over dimensions when using invnetor!
Not sure what others think!
iUser
@pierre.masson Not sure if this is what you want, but from what I understand this exists already and has for a long time:
Dimension Eg
You can preset all your styles using the styles editor under the manage tab:
Dimesion Styles
rodney.pudneyTNG8B
You can only offset from the part not actually from dimension line it's self.
It needs a dim F where you can set an O/A length for the dimension line
Any help you can give will be much appreciated.
bb31ywj
Hope this could be solved ASAP
