Fix Project Geometry Error
I added a new part to my assembly. I clicked on edit the part. I chose a plane to start a 2d sketch. I clicked on project geometry. I clicked on an edge of a rectangular shape. I get a "Projection of the selected curve would result in a point" error message.
I know that it will result in a point, that's why I chose that edge. I want to project a point onto my sketch. In fact, I'd like to end up with two points so that I can draw a line between them.
Please fix this flaw in Inventor.
2 Comments
You can't see the cursor or commands being clicked in your video.
However, adaptive projection has some limitations compared to in-model projection.
Try projecting this edge end-point. The effect will be consistent with your goal.
nickada
@kacper.suchomski
Thanks for the suggestion. The problem isn't that I can't figure out how to project the point, the problem is that Inventor knows that the projection should result in a point so the software SHOULD PROJECT THE POINT!!!!
