Fix Crtl+O After a Part is Opened
This is purely for increasing workflows using keyboard controls.
When you open a part in Inventor, and want to open another part right after opening that first part, you cannot do this using Crtl+O. The program window has to be clicked again for the keyboard controls to mean Jack-Diddly again...This is dumb.
9 Comments
DRoam
Hmm, I can open multiple parts one after the other using Ctrl+O. This is using Inventor 2017.4.8. What version of Inventor are you using?
janelson33
We are using 2019 here, about to go to 2020 as we're on a subscription plan.
DRoam
@johnsonshiue, is this a known issue in 2019? Or could it be something specific with janelson's system?
jtylerbc
I'm not seeing it on 2018 either.  Looks like it's either somehow environment-specific for janelson, or it was a new 2019 issue.
ChrisMitchell01
This is working Ok in 2019.4 for me (tested on win7) - what update level of 2019 are you using ?
Chris
janelson33
I'm Inventor Professional 64-bit, Build 330, Release 2019.4 running on a Windows 10 machine.
johnsonshiue
Hi Jarott,
Are you running any other add-ins aside from the ones included in Inventor Pro?
Many thanks!
Johnson
janelson33
Hey Johnson,
Other than the Screencast tool, I can't say that I have anything else added in, but I'm not sure if Screencast is classed as an add-in in that regard.
JarFu
Hi Janelson,
I tried with 2019.4 with screencast add-in locally, the Ctrl+O works fine to continue open file after one document open.
But I noticed if switch to My Home page and click on any blank area, then Ctrl+O does not work. And it seems related screencast add-in indeed because after unload this add-in (from Tools> Add-Ins) then repeat click blank area on My Home Ctrl+O works again.
Could you try if unload screencast recorder add-in can work around in your case? Many thanks!
