Fitted rectangular pattern with end offset to plane or vertex
For example, when making a rectangular hole pattern along an edge of a part, it would be nice to be able to input an end offset to a plane or vertex when using the "fitted" option. So the last hole of the pattern isn't on or past the edge of the part but a certain distance before the edge of the part (which most people want 9/10 times).
13 Comments
I am really hoping to see additional functionality of the patterning tool where you can pattern a feature (eg. a hole) up to a reference (edge, vertex, face or plane) and also to be able to offset in regards to that reference.
For example, a sheet metal bracket needs to have N amounts of holes evenly spaced out along one of its faces, whereas the first and last hole needs to be offset 15mm from each end. If you wishes to have the part parametric and not have to constantly redo that hole pattern (if you change the brackets length for example), then you're required to create a user parameter referencing a driven dimension from a construnction line. This is both tedious and time consuming, especially if you have a large assembly requiring many joining holes (eg. blind rivet joints).
I am migrating to Inventor from a different CAD package where this functionality is available and I miss it so much.
34780829FWL
Community Visitor
yeah this is too true i agree
MKE_Howard
Hi @sebastian_wilhelmssonMJYC3, im not 100% sure if its what you are talking about but heres a video about a parametric hole pattern : Fully Adaptive Good Practice Hole Patterns | Autodesk Inventor Tip
Again if my understanding of your problem is correct, you can also edit your hole sketch, add a pattern inside the sketch and constrain it so both holes at the end are at 15mm of the edge. If you dont want use sketches pattern (nobody does hahaha) then use Fx of the sketches dimensions inside your feature pattern.
Hi @MKE_Howard!
Thanks for the suggestion. I've seen that video previously and done my patterning like in the video, but it is still a time-consuming nuisance. Regarding sketch pattern, I've been taught to stay away from patterning (or doing anything slightly complex) in the sketch environment and instead do it in the feature tree (as a means to maintain stability and ease of understanding workflow I suppose).
krupickaRZCS6
Yes! Exactly.
RajSchmidt
Have you tried working with irregular distances in patterns? That’s available since version 2026.
krupickaRZCS6
Yes, we tried... badly. And I consulted with two of the greatest experts in our region.
daan5GCJL
Yes, i'm aware of the new irregular distances feature. But that isn't what we're looking for.
It's about creating a simple evenly spaced pattern where we can define a starting point, an end point, and then evenly space an X amount of holes in between it. But the functionality of defining an end point is missing.
RajSchmidt
@daan5GCJL : That's an easy one, see the video. Use a sketch to define your pattern.
(view in My Videos)
daan5GCJL
@RajSchmidt didn't know it was possible to attach the pattern to a sketch, so that's a nice workaround, but still feels like it should be easier to accomplish this.
krupickaRZCS6
I need a different distance on the second and penultimate holes.
@krupickaRZCS6 You can do this by using the irregular occurrences mentioned earlier.
@daan5GCJL Please direct any questions regarding features and workflows to the forum.
https://forums.autodesk.com/t5/inventor-forum/bd-p/inventor-forum-en
This is where we submit ideas for features that don't exist (don't confuse them with unknowns).
Yijiang.Cai
Many thanks for posting the idea, and tracked as [INVGEN-93200]
