This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Fill the circle
Fill the circle
Is there a way to just "fill the circle" with the quantity equaly divided, instead of having to calculate 360/12=30, and fill in the 30 too? It would be easy to just select the circle and the quantity.
4 Comments
gregory_nickol
The way I typically deal with this is make the pattern, with whatever number and angle. Then I go in to edit it, and hover my mouse over the number of instances to find out what the parameter was named, in this picture example it's d46, then for the angle I type "=360/d46" so that it will recalculate the angle automatically whenever I change the number of instances. It would be nice to have a toggle button to make it incorporate that formula when the pattern is first created to not have to go back and do this afterwards.
jtylerbc
A slight improvement to @gregory_nickol's method is to actually name the parameter yourself to something logical, like "Hole_Count".
A somewhat cruder method, but possibly still better than what you seem to be doing currently, would be to just let Inventor do the math.  Instead of calculating 360/12 = 30, then entering the "30", just type "360/12" in the entry field.  Inventor is a calculator, so there usually isn't much of a reason to do math outside of Inventor and then enter the results as a parameter.
el_jefe_de_steak
The "ideal" way to do this is to create a user parameter that stores the quantity for you. For example, you could use a parameter called "BoltQTY" that has a value of 12 ul. Then when you create the pattern feature, you set the quantity field expression to BoltQTY and the angle field expression to 360/BoltQTY.
Yijiang.Cai
@johan.degreef, the space angle is depended on the total angle we need to use. If the total angle is 360 as default, the space angle can be calculated automatically. But it is possible that the total angle is not 360 deg but something else, and it will the the count * space angle here.
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
