We have found the following.
The files of drawings are increasing in the course of the project. With each change to the model or to the drawings themselves, the file size increases. The files will reach in some cases up to 100 MB. The time to save such a drawing file is then very long.
Although all content will be deleted from the drawing file (all views, all signature fields, all the frames) the file size will not be smaller.
There should be a function that allows the drawing files will be cleaned to reduce the file size again.
In the picture you can see the used template called "Norm.dwg" with a size of 616 kB. The Projectfile "Project.dwg" has contained some views of an model. There have been done many changes at the model and at the drawing themselve. So the file size increases step by step. Now the drawing is empty (all views are deleted) but the file size is still 98.274 KB.
