Faster Interference analysis for large assembly
We use large assembly.(Total occurrences in active document:over20,000parts)
So,It takes a very long time to run the Interference analysis, it is a problem.
"All Components sets/All Parts sets Options" is very simple and reliable solution.
2 Comments
jasonrecords
Autodesk has a survey out recently asking people to provide feedback on large assembly performance, see link below.
http://forums.autodesk.com/t5/inventor-general-discussion/are-you-frustrated-with-large-assembly-dra...
dan_szymanski
A new option "Treat sub assemblies as components" was made available within the Analyze Interference command in Autodesk Inventor 2017.3.  Utilizing this option on large assemblies will drastically increase the time it takes to obtain interference results.  Likewise you can continue to leverage it by drilling down into sub assemblies at each level for additional analysis.
