Faceted bends in Sheetmetal?
In cases where i want a bigger bend radius then normal for the sheets thickness, i would like to make the bend faceted rather than roled.
Also converting a large radius bend into a faceted bend would be nice.
I was also running into problems getting a seam in a faceted bend i made (multi body sheetmetal) with an other body.
4 Comments
leblanc2024
Hello n.scotten,
It would be nice to have this as an automated feature... I have done this manually with a contoured flange.
Ivon
r_lehmann79
A workaround could be using Lofted Flange Features:
http://help.autodesk.com/view/INVNTOR/2016/ENU/?guid=GUID-B6271A15-FD68-4672-9461-C86F8D55DA87
Regards
Ralf
n.schotten
Thanks Ralf.
That seems to do the trick for a faceted bend. But is rather involved to generate. unlike an option in the bend interface.
Niels
inv.ideareview
Status changed to: Archived
Based on the image, it should be able to get it done using contour flange/lofted flange with sketch profile.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so.
