Extrude surface, without "automatic edge chain"
I would really love to se the option to select single lines from a sketch profile, when using extrude surface. The only option is to select the whole continuous loop of connecting lines. If you could add a check box like in Boundary Patch where you can toogle on/off "Automatic edge Chain", and otherwise make the selection functionality similar to that command, it would be perfect. So that you could also select multiple single lines.
3 Comments
DRoam
FYI for those interested, see a similar suggestion but for the Trim Surface command here: Trim surface using sketch profile, without "automatic edge chain".
Also see another related request here: Select Multiple Non-Contiguous Sketch Profiles for Surface Extrusion.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
