export Model States as .rfa types
When using the BIM Content Environment to export Inventor designs as .rfa files for use in Revit. It would simplify workflows a lot if different model states can be exported within a single .rfa file as different types. Now a designer has to export each model state separately before an architect can use them in Revit. It also makes file management a lot more complicated for both the Inventor designer as the Revit architect.
Ideally when exporting to .rfa the designer could also choose which model states (by dropdown/check-box) should be included and which should not be included. This way model states meant for production purposes, or which are still in design can be excluded.
