Export the flat pattern from a sheet metal model as Step or Iges
i think there should be the option to export a the flat pattern from a sheet metal model as Step or Iges.
In version 2018 there is only the possibility to export as *.sat, *.dxf or *.dwg.
Some of the sheet metal laser systems working with step.
A workaround is to export as *.sat, than import this and after that export it as step.
But i think that is not the right way for a full-size- and full-prize-system.
Best regards
Michael
5 Comments
Yano4321
Where i work, we have a Plasma Plate cutting machine and I export dxf from Inventor for cutting on it. Of course, dxf do the job but the nice thing about step files is it knows the thickness of the plate and we don't have to manually indicate it. The problems is that we cant export the flat pattern in step. It would be really useful to use step files flat pattern from Inventor. It the best 3D CAD software for sheet metal work so I think am not the only one who will use this improvement.
dan_szymanski
Idea added to backlog for future consideration [68991]. Thanks!
dan_szymanski
Status changed to: Accepted
Yijiang.Cai
This idea has been implemented within Autodesk Inventor 2024.2. Please review the Inventor 2024.2 What's New article here. For more information regarding how you may leverage the feature, and please review this page. Special thanks to everyone who cast a vote for it.
m_numberger
Thank you
