Hello
When we import a .ipt file as derived part as surface, it is completely imported as surface and it does not shows any physical value.
Steps to reproduce
1. Created a part file(.ipt) create a cube consider Volume of the cube is 100000
2. The same .ipt file inserted it as the derived part in another part file as a surface the physical value not taken in account it shown as zero.
When we import a .iam file as derived part as surface, then why it is not completely imported surface and it shows physical values.
We expect that physical value to be shown zero when we import .iam file as a derived part as surface.
Steps to reproduce
1. Created an assembly with two cube and consider volume of the whole assembly 200000
2. the same assembly file is imported as the derived part in a part file as a surface here in this case, it not completely imported as a surface and it shows the same physical value of the assembly
To achieve this, we have to simplify the .iam file as a part file and then we use it as derived part, the physical value not considered into account. But for the users it is double job, so it is better if we directly import .iam file as derived part so the physical value to be shown zero.
