Show only
Search instead for
This idea has been implemented within Autodesk Inventor 2016. Special thanks to the author of this Idea and likewise to everyone who cast your Kudo for it.
A test code button would work, so that it runs the code before actually applying it to the part/assembly. It would give any errors, prints, messageBox, etc. while retaining a break or cancel command.
I can't believe I'm reading a thread that started 11 years ago where it claim to have been implemented but clearly hasn't. Why is there not a cancel operation button/shortcut yet? It's 2024.
Shhh... don't mention SolidWorks here or you will make AutoDesk feel bad. SolidWorks has scary features like autosave that have only been standard for 30 years.
I realise this is still an issue, this is what I do when I know I may want to stop a rule running. I create an empty text document, create a clause in a large iteration For loop that exits the rule if an 'x' is placed in the text document. For example:
Forx = 1 To 100000000
Logger.Info(x)
IfSystem.IO.File.ReadAllText("C:\TEMP\killer.txt").Contains("x") ThenMsgBox("PROGRAM CANCELED")
ReturnEndIfNext
