Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
ESC key stop operation
the ability to stop all operations/calculations with ESC key instead of killing the inventor.exe process!
33 Comments
fprico
- Shell
- loft
- Autocad import manager
regards.
please also for iLogic!!, now if you are in a loop, you 'll have to kill Inventor, and lose not saved code!!
thanks
dan_szymanski
This idea has been implemented within Autodesk Inventor 2016. Special thanks to the author of this Idea and likewise to everyone who cast your Kudo for it.
michael_marx
Yhuuuuui
First discussed this wish at Bootcamp 2004 in Austria (Salzburg) Smiley Very Happy
WHolzwarth
I'm just stumbling in here. I can't break most processes with ESC in 2016, and I think, in 2017 it's the same situation.
Walter
cmcconnell
It would be nice if the Cancel happened much quicker and worked for all commands.
jholland3XDLM
This does not work for endless loops in iLogic.
A test code button would work, so that it runs the code before actually applying it to the part/assembly. It would give any errors, prints, messageBox, etc. while retaining a break or cancel command.
Solution found at long last!  Go to Task Manager, End Task on Inventor, then reopen Inventor and redo all of your work.  Practice makes perfect!
SevInventor
ESC has no effect Inventor 2019. please really implement it.
@Anonymous please let the customers do the acceptance before its called implemented.
Have all the ideas, posts and votes been in vain and a complete waste of time for everyone who tried to make things better?
I can't believe I'm reading a thread that started 11 years ago where it claim to have been implemented but clearly hasn't. Why is there not a cancel operation button/shortcut yet? It's 2024.
cstarker6VCG4
https://forums.autodesk.com/t5/inventor-ideas/esc-key-stop-operation/idc-p/4351719/highlight/true#M2...
Shhh... don't mention SolidWorks here or you will make AutoDesk feel bad. SolidWorks has scary features like autosave that have only been standard for 30 years.
mmurray9LEHM
I'd like to know what functions the escape key works on?
There's no function that every responds to the escape key (at-least instantaneously).
It's 2026, and this still hasn't been figure out?
Maybe we'll get under-glow, or new button sound effects in 2028 as a concession?
I realise this is still an issue, this is what I do when I know I may want to stop a rule running. I create an empty text document, create a clause in a large iteration For loop that exits the rule if an 'x' is placed in the text document. For example:
For x = 1 To 100000000
	Logger.Info(x)
	If System.IO.File.ReadAllText("C:\TEMP\killer.txt").Contains("x") Then
		MsgBox("PROGRAM CANCELED")
		Return
	End If
Next
 Does the trick.
Harvey
