Dear all,
Please rework the behavior for the Configure Default Template feature.
In our case we are using 2 project files (in all vaults), to have different templates for ISO and ANSI templates. We tried to use the Configure Default Template feature to merge the project file into one.
We can not use this feature because:
- Standard.dwg must be existing, that Standard.idw is copied (we are only working with idw)
- Copy does not work if Mold Design (mm).iam is missing
- Other ipt or iam templates can not be copied
I would suggest, that there is an xml file in design data, where all possible combinations (mm/ISO, inch/ANSI) are in and where you can define, which files should be copied from Metric/English folder. So we are more flexible with additional template files than the standard ones.
Additional in the XML it would be nice, that there is a setting where you can define if the standard drawing template is DWG or IDW (possible to set up in Application Options at the moment) and which combination is set on initial start up.
Thank you to take care about this.
BR Hatl
