Enable to reflect a frame length after notch to BOM
This seems to be not a bug but a limitation.
A frame length after notch will be reflected to the Frame Member Info but not to BOM.
http://autode.sk/2r31kH9
This could make a customer to be confused. I think Frame length after notch should be reflected to BOM as well.
1 Comment
jtylerbc
My company's custom Content Center families avoid this issue by using iLogic code to measure the extents of the part in the appropriate direction instead of relying on the Autodesk-supplied "B_L" parameter.  We have found this to be much more reliable in reporting the correct length, no matter what operations have been performed on the part.
