Show only
Search instead for
When right-clicking on a sheet in a drawing you can edit the revision of only the sheet, not like in the iProperties of the whole drawing (including all sheets).
It would be nice, if it's possible to read/write this property over the API.
Using iLogic or VB, the properties for a drawing sheet's Name and size are available. However, I can't find a way to reference the object for the Sheet Revision. This is different than the iProperty for the drawing file Revision.
My apologies -- you are correct! The "Revision" property was added in 2019. The direct link to it in the documentation is broken, but you can see it listed under the Sheet properties here: Inventor 2019 Help: Sheet Object.
I'll report this Idea and ask the moderators to mark it as implemented. Thanks for sharing that, @fsanchou!
