Enable bounding box for constraints in sketch environment
Would be great if Autodesk would change the bounding box behavior when constraining lines ect. in the sketch environment. Currently you can select two lines and select a constraint like co-linear and it will make them co-linear. Instead they should also make it so that you select your two entities with a bounding box and then select your constraint. It would save a click every time you constrain two entities close to one another.
2 Comments
CCarreiras
And why not more then 2 elements at once?!
Example, we need a bunch of holes with the same diameter... why select two each time when we should select all them with a drag selection window and just select EQUAL!
iUser
@CCarreiras Yes, I completely agree, this would save a lot of time. Think of all the mouse button clicks one would save.
