Edit Values in Hole Property Panel with Tab Button including Diameter
If you navigate with the Tab- Button through the Hole Property Panel the Diameter can not be reached.
1. Value1. Value    after Tabafter Tabnext Tabnext Tab
2 Comments
Steven_Gao
Hi Frank,
Please note the first active dimension is hole diameter. If you not change any value and Tab button will cycle the dimensions and will include hole diameter.
Steven
Having the hole diameter as first active dimension does not always work, especially when rotating with a 3D-Mouse.
In earlier versions, the hole diameter was selected using TAB after changing bore depth.
So this new workflow of 2020 is unfamiliar and counter-intuitive. I agree with Frank_Wald.
