Suggestion for Autodesk...
With both an assembly file and a part file open in separate tabs I would like to create a sketch on the part from the assembly file. When I click down part from the assembly, Inventor switches me over to the part file and I can't project the geometry from the assembly that I want to. I need to close the part file in order to work on the part sketch from the assembly.
Autodesk tells me that this currently is the correct behavior. We have discussed having the following added under Application Options but they need more people to speak up to make it happen. Who's with me?
Application Option
1) Edit component in place
2) Edit component in open window
3) Ask me to define behavior during edit
https://forums.autodesk.com/t5/inventor-forum/creating-a-part-sketch-from-an-assembly/m-p/6782289#M6...
