easy way of creating simple parts
in assembly insert simple parts which are created by just filling in the dimensions.
for example a rectangular piece or rod is needed. click insert rectangular, fill in the dimensions 200x100x2mm and it automatically generates the new part.
3 Comments
mcgyvr
@Anonymous Peter are you familiar with creating parts in an assembly..
Its pretty darn simple now.. and takes seconds to create a new part in an assembly..
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Inventor-Help/files/GUID-0FE24C8B-B570-41F7-A12C-BF98ED19ED1B-htm.html
You can also use "primatives" too which automates the process of creating a "box" by stepping you through the sketch and automatically invoking extrude dialog..
https://synergiscadblog.com/2013/07/30/working-with-primitives-within-inventor/
Obviously you need to select a "template" to use for your part too (how would your method achieve that?)..
So its not as "easy" as just placing a random box into a file.. This isn't a "graphics" program.. There is more to it than that..
A part needs a part number.. A part needs a template to bring in the styles/appearances/materials,etc..
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
