多实体识别,并分组为相同的实体
多实体识别,并分组为相同的实体
用户在导入第三方多实体模型时:
实体数量多,进行识别分组后,可能只有几种,更多的情况下,是同样的实体有多个实例。
见附件:
导入第三方零件,同样是53个实体。
在SW中,点击焊接,【切割清单】会将53个实体进行合并相同实体。
INVENTOR中没有整理的过程。
3 Comments
enochbQS6E9
Take a look at my add-in "iBuildList". It creates a list with the identical bodies grouped together. It's just in English but more languages is something I would consider adding if users want it.
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=5877949538905076499&appLang=en&os=Win64
zhangchuhwa
I’m very pleased to see your response so quickly, and it is exactly what I need.
I look forward to this feature becoming a native function in INVENTOR.
Reason:
This also involves workflow issues. For example, when we use the Structure Generator,
when creating a new structural component, the software asks me whether it is a design reuse.
In fact, similar questions should be addressed after the design is completed and then organized.
At that point, the software should perform the identification.
zhangchuhwa
进一步的工作流:
生成装配时,例如上面的例子,是由12种实体构成,而非目前53种实体。
