I am constantly asked to slightly chamfer the entry and exit of holes that we drill in a CNC machine. This way, all the holes are deburred right out of the machine saving us having to hand deburr it afterwards.
When using the hole command I would love to have the option of adding a chamfer on both ends of a drilled or tapped hole and on the top of a counterbored or countersunk edge.
Currently I put the holes in and then use the chamfer command to add the this detail. The down side is when I detail the parts, the hole label does not note the chamfer so I need to use an additional label on the same hole or manually enter it into the hole label.
The hole label should be able to produce text that calls out the chamfer (or edge break) on this side, far side, or both sides in addition the the text that is currently available.
ex.
8,5 mm DRILL THRU
M10x1.50 TAP TAP, 20 mm DEEP
.035 x 45 DEGREE CHAMFER, BOTH SIDES
9 mm DRILL THRU
15 mm COUNTERBORE, 9 mm DEEP
.025 x 45 DEGREE CHAMFER BOTH SIDES
(keep in mind that my examples do not contain all the geometry symbols that the hole labels show but you get the picture)
There are also other hole functions that I need to do (but can't think of right now) in multiple steps. This makes me use multiple hole labels or manually edit them. Can you just expand our hole options beyond the basics??
