Drawing notes wizard
I wish for a Drawing notes wizard that behaves like footnotes. It would use symbols like a triangle note and be associative to a line item similar to the revision tag functionality.
2 Comments
dvsmiller9
If we could add sketched symbols to notes and link them to other sketched symbols we could put a flagnote pointing to some feature on a view and put the same flagnote in the notes.  If the text in one flagnote changed then the text in the corresponding flagnote would change.  Currently we have to update them separately and leave space in the note text to manually overlay a sketched symbol on the page in the proper position.
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. The product team continually reviews this forum aiming to deliver in the most impactful way we can based on voting. We also regularly examine the list to make sure it reflects the most current Ideas. As part of this process we archive old Ideas that haven’t received broad support. This ensures there is room for new Ideas to be reviewed by the community and for the most relevant and meaningful ones to gain votes.
This Idea is archived because it's been on the board for over a year and hasn't received many votes. If you want to raise it again and try to gain more support across the community, you're welcome to do so. Leveraging images, animated gifs or sample mock-ups can help convey concepts and generate more votes from other users. If you have questions or see a connection between this Idea and others that should be accounted for, please let us know.
- INV.IdeaReview
