drawing display line weights UI toggle button or shortcut
Often when I'm working on a drawing I'll want to toggle "options - drawing - display line weights" to either make sure I select the right line (off) or to make sure the lines are clear and distinct when published (on).
It would be good to be able to toggle this either via a ribbon button or a keyboard shortcut, to avoid the need to go through the options menu every time.
1 Comment
I think you can ask about the macro on the iLogic support forum:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/bd-p/120
