Direct Edit, Rotate Faces Command Does Not Allow An Angle of Rotation Greater Than 119°, Why?
Just as it says, why did the Inventor coders decide to limit the angle of rotation on faces to 119°? Crazy. So, I need to rotate these particular faces 135° total, and must do it in two separate operations, one at 110°, the second operation at 25°, just to trick Inventor into doing what it should be capable of doing in one single operation. Fix this asap.
