Hello
When creating sheet metal parts, I often make parameters dependent on other parameters.
This is very easy to do, since the relevant parameters (d0/d1, etc.) are displayed when creating the dimensions.
See Bemassung.pdf
However, when creating a flange, for example, the dialog box displays “Abstand = 25 mm” instead of the parameter.
Only after the flange has been created and “Edit Element” is selected does the corresponding parameter (d7=25 mm) appear.
This makes it more cumbersome when, for example, I want to set a dependent dimension for another flange.
See Lasche.pdf
The same applies to parameters in assemblies.
When I create a dependency, the dialog box displays “Versatz = 10 mm.” Only after setting the dependency and reopening the dialog box is the corresponding parameter value (d40 = 10 mm) displayed.
See Abhängigkeit.pdf
Best regards Urs Meier
