Dimension round off to nearest 10mm or nearest 20mm, etc
Sometimes we don't need dimensions to the nearest millimeter. We should be able to round off to the nearest 5mm or nearest 10mm or whatever is required.
36 Comments
FProcp
A draftsperson should NEVER over-ride a dimesnion.
We have people here at my work over-riding dimensions to round them off.
It would also be helpful to round-off to the nearest 5, 0.5, 0.005 etc
Sheetmetal work is rarely measured to anything smaller than 0.5mm as that is the smallest increment on an engineering rule.
Furthermore, 2.5, 0.25 and 0.025 etc are also helpful as some older title blocks and company standards use the accuracy of measurement to define the general tolerance
For exmaple
DIMENSIONS TO THE NEAREST
10mm = ±2mm
5mm = ±0.5mm
1mm = ±0.1mm
0.5mm = ±0.05mm
0.25mm = ±0.001mm
Above might not be a very good example as it was rushed, but it is a demonstration of how is works.
A more simple approach on the programming side might be to expand the "Precision" dropdowns to include "10", "100", "1000" on the topside of "0".  Might be able to include "5", "50", or "0.5" and "0.05" to get dimensions to the nearest half.
swalton
Why not edit the model dim to be what you want?  It seems very dangerous to have a difference between what is displayed on the print and what is modeled in the 3D file.
I don't see the advantage of false dims on the print.
FProcp
Why not show all dimensions to full nine decimal places?
Do a web search on the term significant figures of a number.
It's the digits that carry meaning contributing to its precision.
In many cases too much accuracy is a waste of time and is unnecessary.
That's why we can choose how many decimal places we want to show.
It all depends on the situation. Is it a precise tolerance engine component or something much less accurate.
It's very common in structural drawings to round off dimensions to the nearest 5mm.
The fabricators are NOT going to measure the steel members to the nearest millimetre.
So it's a waste of time showing it.
Can't the drawing be switched to display in meters/centimeters?  Wouldn't rounding remove the significant figure aspect since it's going to maintain all the digits until it hits the 1 column?  I agree it's a good idea, but I don't think significant figures is a valid argument for it.
So i see the discussion point and agree with a comment that "It's very common in structural drawings to round off dimensions to the nearest 5mm." So how to round up to nearest 5 mm??
I have been trying this but havent figured it out yet. Any help would be great!
lesmfunk
Thought I'd give this idea a bump. Cable and Harness, or Tube and Pipe (Hoses) would make good use of this option. The nearest 10mm would be ideal. 0.01 meters is too cumbersome and nobody uses centimeters.
In response to swalton, try to get your wire or hose to be exactly 3450 mm. It is near impossible unless you want to work at it for 3 hours. Especially when you want five wires to the nearest 10 mm but changing one affects the rest of them. And, in regard to "false dims", show me a true dim. There is no such thing since there will always be rounding to some precision. We just want better control of the precision.
binuvarkey
We make refrigerated trailers and dimensions in fibreglass body is always shown and measured in nearest 5mm in AutoCAD drawings. When the beams are wrapped in fibreglass for a length of 12~14 metres we cannot draw to nearest 5mm on each beam as the rounding on each beam will cause huge difference in the other end.
Since Inventor does round dimensions to nearest 1mm (preciaion 0), the dimensions shown are not true dimensions anyway. Then why can't we round the dimensions to nearest 5mm or 10mm?
We need this ability to draw our Fibreglass parts in Inventor.
It would be sometimes useful to be able to set rounding dimensions in IDW to what ever you want, like it is in Autocad.
For example: you have general drawing showing something that is quite big but for some particular design reasons dimensions are not so round for example 1500236,36.
In genera view this 236,36 is not important and you would like to be able to have dimension rounded to 1000 in this case.
Currently it is not possible.
Allow rounding dimensions in .idw to 1, 5, 10, 100 ....
Cris.
magnusn
Are there any news on this subject? My company is about to update from the old Inventor 2012 to 2016 these days, and I'm wondering if there's been any changes regarding this issue. Since the previous posts that are not too old, I'm afraid not.
As others have stated, it would be very useful to be able to round off to the closest 10mm or even 100mm, instead of showing dimensions like 18507mm to a fabricator equipped with a chainsaw. Hence, I'll override the dimensions way more often than I'd like to. It's time consuming and somewhat risky too, because if I change the geometry of a part, a dimension in the drawing that has been overridden doesn't change while the others do. Sometimes I use meters as the scale, but very often it doesn't work well in other parts of the drawing, or in other drawings within the same document. So I would definitely need the possibility to round to the closest 10 or 100mm, hopefully it will get implemented soon.
Another related issue... I would often like to make all drawings related to a certain project in one and the same file, but it doesn't seem possible to separate units for different sheets. Am I doomed to make separate files always when different units are needed? I've checked out the alternative units system, but it doesn't work at all the way I'd want.
How is this not a thing yet? Upvoted and bumped for good measure. (see what i did there? 😄 )
Cadkunde.nl
I currently have a dimension 2249.4435 and I want to round it to 2250.
I am torn to override the dimension, but I have to I fear.
For me this simple addition would be sufficient in right click precision list:
1000
500
100
50
10
5
0 - [0]
1,1 - [1/2]
2,12 - {1/4]
3,123 - [1/8]
Etcetera
And make this precision table available in application options - drawings tab (or Styles Editor - dimension), so you can checkbox on and off which precision you want. For example, I never had to set a precision lower than 1,1.
I'm another one (and there must be thousands of us!) who'd like to see this, although my usual wish would be for plus or minus 0.5mm.
Fed up with being told about significant figures, and this is not the same thing!
Come on Autodesk, how many years does it take? I can't believe this is a difficult task.
francesco.dinh
I'll chime in supporting this idea. Still no news?
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
joesbartels
This needs to get implemented.  It already exists in AutoCAD dimension styles, but not Inventor.  We now have to use Inventor to model, and detail in AutoCAD, causing us to be inefficient.
erikH9WBZ
We are waiting for this a very long time! We make truck bodies and work with tolerance of 1 to 10 mm. Some equipment is mounted to the truck chassi. Because we don't always have the precise information we draw the equipment on the theoretical right place, but we mount it in such a way that we can use the original mounting holes and/or brackets. Why put on a precision that we will never use.
Please Autodesk, make this option available!
b_ruijter
At my company there is a "Round to 10mm Dimension style". The way they did this is set the Units to cm and aadd a zero as a Suffix. See screenshot.
Untill Autodesk speeds up this setting (adding it to the precision looks like the way to go) it pahaps could help you guys.
