So we all know how dimensions in a sketch are labeled d# and the # is whatever the next number in line is. And then we can use the dimension in other dimensions of the part. Ex. d2*2 is twice as big as whatever d2 was. Constraints also have these same dimension tags but in order for you to know what it is, you have to finish the constraint and then go into the browser to find its tag. Can we get this ID tag placed in the constraint tab so if I want to use it somewhere else, I don't have to go find it and I can just type it into my next dimension like a sketch. In the attachments I screenshot a sketch dimension verse using a constraint. As mentioned, it'd save time if the dimension ID tag (d#) was on the constraint window.
