Derive parts from mirrored assembly
It would be great if when you mirror an assembly and inventor creates mirrored parts if those parts had the option do be derived parts. That would allow the ability to update the original and not have to either redo the mirror or make the same edit on the mirrored part.
5 Comments
Have you looked at the derive part dialogue box?
On the Manage Tab in a new part file, click on the Derive button of the Insert Panel
There is an "Options" tab and in there at the bottom right there is a tick box and drop down selection that allows you to mirror via any of the Origin Planes.
Be aware that you will need to update the mirrored part to reflect any changes you made in the original assembly and that all changes will be made in the mirrored part when you do so.
I think this is what you were asking, and apologies if I've misunderstood.
jamesc
Thanks jas25t, but that is not exactly what I am talking about.  When you are in an assembly you can creat a mirror of multiple parts, but it creates a new mirror part that is not derived.  I think adding a derive option would be great!
Doing a single derived part means you would have to rebuild the whole assembly in the mirrored version.
Sorry if I wasn't clear. The way I was showing just does the same function counter-intuitively.
Although for me, if I ever wanted a derived part, mirrored or not, I would always start with this function.
It would be very handy to have it within the mirror function itself.
DRoam
@jamesc, what you're asking for is already the current functionality. If you select the "Mirror" option (the green logo with the double arrows), you get precisely what you're asking for: a Derived mirrored version of your original part. If you make a change to the original part, the mirrored version will be updated.
Am I misunderstanding what you're asking?
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that
pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
