Derive component command copy/link original part materials.
Example, you've created LH, RH versions of a part where one if derived from the other. Since the parts are similar, there should be an option to link the material from the source part to the new derived part or to copy the material into the derived part.
1 Comment
Very Handy when you use a skeleton model as derived part. Only one click in the skeleton model changes the whole assembly material.
