Delete Constraints on Specific Components
I've run into the case multiple times that I make a change to a part in an assembly, or the assembly itself, in which it really is easier to just start over than continue forward. This usually looks like an .iam with HUNDREDS of constraints and a large portion of those are 'sick'. There is already a proposal to add the functionality to delete sick constraints (I simply use an ilogic rule for this now, so its a nicety to add true functionality) however, once i delete the sick constraints, I am left in pergatory. I'm not really sure what all broke and what is fine. In most of these cases, it would be easier to reconstrain some/many of these parts from the ground up rather than to try and work with the remaining mess of constraints.
I would like to be able to select a group of components and delete the constraints on those specific components all at once.
Perhaps with some optional criteria, maybe i don't want to delete angle constraints or something like that, but even if ti could only delete all of the constraints, if i could specify the objects and remove them that would be ideal.
Thanks for reading!
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
