The ability to select all broken sketch projections (and delete them) has been a great addition to Inventor. Unfortunately, this workflow is incapable of deleting projected points if they're constrained to the endpoint of a sketch curve. This goal of this idea is to remove this limitation, so these points are deleted along with the other objects.
The current solution for this situation is to...
- Right-click > "show all constraints", then go around deleting the leftover projection constraints, one by one.
- Alternatively, you can window select them all and right-click > "delete constraints", but that risks deleting others that you might want to keep!
- Lastly, reference points disappear completely once the projection constraint is gone. Center Points will remain but will be "unbroken". This nuance doesn't really bother me.
Whether these limitations are intentional -- and why? -- I have no idea, but we deal with this often enough that we wrote an iLogic rule to take care of it. Now we can blast away every broken projection in the model with one click if we want to.
My point is it shouldn't have to be like that -- I bet there's plenty of people out there that could benefit from this simple change. Please Vote!
